Posted by Joe Kimbriel on March 24, 2008 at 19:03:30 from (76.14.108.155):
I have asked here before about having to run the Super C with the choke half on. The suggestions were carburetor needs cleaning. Did that over and over and still it’s too lean or rich depending on choke position. Vice grips work great, and if you see a Super C at the Tulare parade running around with a pair clamped to the choke lever, you will know it"s me. I sure would like to know what’s wrong though. I finally switched carburetors and still the same problem. When I removed the LPG carburetor I noticed two holes in the manifold. This didn’t look good so I plugged them. I pulled another manifold and there were holes in it also but did not go all the way through. What’s wrong with this beast? Is dynamite the answer? Thanks, Joe
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
