Re: Maybe dynamite would cure it.
Posted by rls_ia on March 24, 2008 at 19:25:52 from (216.145.142.37):
In Reply to: Maybe dynamite would cure it. posted by Joe Kimbriel on March 24, 2008 at 19:03:30:
Have you checked the air cleaner? Sometimes the pipe going to the air cleaner (the one thru the hood) gets oily dirt accumulated in it cutting down air flow. Have you ran it with the oil cup off to see if it is getting enough air?
Bob
