Unless the manifold is ABSOLUTELY air tight no amount of carb work will get your tractor running properly!
So make sure the holes in the manifold are solidly plugged. Then check there's no cracks anywhere - even hairline cracks - or pinholes anywhere on the manifold..
The check gaskets between the manifold and the head; also between the carb and the manifold. These too must 100% air tight.
Now your problem could also be a cracked head or blown head gasket. But these will also accompanied by water/oil leaks, poor compression/loss of power, etc.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
