Re: Hydraulic jerks on Farmall Cub
Posted by Tab on March 25, 2008 at 06:39:59 from (4.252.36.43):
In Reply to: Re: Hydraulic jerks on Farmall Cub posted by mkirsch on March 25, 2008 at 05:09:17:
Let me get this straight before I attempt anything. When I drained and re-filled this last Fall, I lowered the arms all the way down, pulled the drain plug and drained all of it out(then put the drain plug back tight). Then, I filled until it ran out of the fill-hole. Put the plug back in tight, and worked the lift. I DID notice that the lift wasn't leaking down(while sitting) before I changed the fluid. Now, it will leak down over the course of a couple days. So, the air cannot get out of the system unless I remove the fill plug and cycle the lift? Any idea how many times I need to cycle?Thank y'all for the advice!
