I've been fighting about the same thing with my 2606. You can see a lot of my threads on it if you search 2606 or 606 or 2656. Took me a while to figure out what I had. The parts guys in Hutch have been very helpful to me.
Your 560 doesn't have the hand pump like mine. I looked at the picture in the book for yours but I'm not sure I understand it. My main problem turned out to be a piece of metal under the ball of the bypass in the draft control housing.
Are your hydraulics whining or squealing which might be indicative of fluid squeezing through a bypass?
One way to see if the steering cylinder is leaking internally by the seal is to turn it all the way in one direction. Then disconnect the opposite line and keep trying to turn it in that direction. If it is not leaking then nothing will come out.
While you are at it, turn it back the other way to see what kind of flow you are getting. When mine was bypassing, it just kinda spit out some fluid with hardly no psi. Then reattach the line, turn the wheels the other way and remove the other line and do the same test.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
