First, I'd get both wheels filled with the same amount of fluid and filled to the maximum.
The further out you hang the weight, the less weight you'll need, but then you compromise maneuverability. That blade will get in the way in tight spaces.
What I've seen used most commonly is a simple mass of concrete connected to the 3pt hitch. You get a 55gal drum, shove a 1-1/8" steel bar through the middle, and fill it with Sakrete and rocks. Sometimes I've even seen them cast into large blocks instead of cylinders, even.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
