MD's are too big to pick up and throw!
Posted by Peculiar Farmer on March 26, 2008 at 07:41:22 from (64.19.38.166):
My first time at replacing a distributor and beginers luck didn't show. I aligned the mark on the pulley with the pointer, installed the distributor with the points open and rotor on #1 cylinder. Pulled the switch, pushed the starter lever and after three rounds got a dandy backfire so I rechecked alignment, unlike the old one, everything was the same. Are there 2 marks on the pulley, one for TDC and another for X degrees BTDC?
