Re: MD's are too big to pick up and throw!
Posted by Janicholson on March 26, 2008 at 09:49:54 from (199.17.6.122):
In Reply to: MD's are too big to pick up and throw! posted by Peculiar Farmer on March 26, 2008 at 07:41:22:
Pulley marks are at TDC compression, or TDC exhaust. Thus the explosion. Use your thumb in the #1 spark plug hole while turning the engine in the correct direction to find compression, then turn to the mark. Common issue, JimN
