Re: little tire problem ..which to do....
Posted by mkirsch on March 26, 2008 at 09:52:22 from (64.80.108.53):
In Reply to: little tire problem ..which to do.... posted by Clefus on March 26, 2008 at 08:48:24:
As far as I know, the 15.5x38 is really the same width as a 16.9x38 and the same height as a 13.6x38.
Worst case, the rim might be an inch narrower than the recommended rim for a 16.9x38. You can squeeze the tire on there and it'll work fine.
If Galaxy no longer has 15.5x38, then you will not want another size Galaxy, because the tractor will be lopsided. In that case your only option will be another 15.5x38 (and mismatched tires) or buying a pair.
