Re: To Hugh MacKay....
Posted by El Toro on March 26, 2008 at 13:42:36 from (64.12.116.73):
In Reply to: To Hugh MacKay.... posted by 1fortyfanatic on March 25, 2008 at 21:20:30:
You need to see what the charging voltage is at the battery when the engine is at 1/2 throttle or better. On a 6 volt system it should be around 7.25vdc on a 12 volt 14.5vdc. Which vehicle is this? BOB M has wiring diagrams for troubleshooting Generator & Regulator problems. If you need it post back I think I have that somewhere. Hal
