Re: Hydraulic Pump and Touch Control Pistons
Posted by Greg-N-CA on March 26, 2008 at 17:04:35 from (63.206.206.254):
In Reply to: Re: Hydraulic Pump and Touch Control Pistons posted by P and R Pete on March 26, 2008 at 13:20:14:
Or, "Greg's Machine Shop," seal jumper tools only $150.00 ea! I've got about 2 1/2 hours into making that tool, but then I'm kinda @n@l about turning something on the lathe. It was fun though.
It sure made sliding the pump assembly back together a breeze. Just make sure you keep the bushings in order, it make a difference going back together (don't ask me how I know).
Have you gone into your steering box yet? I have the CR seal numbers for the sector shaft and steering shaft. If you buy them locally, you'll save quite a bit over the same thing from Case/IHC. The new seals are thin enough you can use two of them for a "double" seal on the shafts.
