Re: finding a 330 Utility transmission drive shaft spacer
Posted by CNKS on March 26, 2008 at 17:29:53 from (216.144.104.128):
In Reply to: finding a 330 Utility transmission drive shaft spacer posted by mdaitc on March 26, 2008 at 16:40:28:
Although I am not familiar with that particular tractor or part, you probably have 3 choices: 1. A speedi sleeve or redi sleeve (both trade names) 2. see if you can move the new seal to a different position (probably not likely), or 3. have the groove filled by a machine shop that is familiar with the procedure to do it right. Don't simply have it brazed. Or--try to find parts in a salvage yard. In that case compare part numbers on the Case-IH web site-caseih.com to give a wider range of tractors to look for.
