Leaking oil seal on Cub
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by George on March 06, 2000 at 08:15:10 from (12.78.103.63):
54 Cub has oil leak from front oil seal. The manual shows a special tool being used to remove the pulley from the crank so that the cover can be removed to get at the oil seal. Can the pulley be removed with an ordinary 2 or 3 jaw puller or do you need some kind of special tool? Since I have to split the tractor to do this job is there anything else I should do while it is apart? Any suggestions or comments would be helpful.
Post A Followup
: Re: Leaking oil seal on Cub
