Posted by Steven f/AZ on March 27, 2008 at 07:15:42 from (216.67.213.217):
In Reply to: Farmall 300 hydraulics posted by Dick fm Iowa on March 26, 2008 at 14:49:24:
If the pump is working/pumping fluid, you should hear a bit of whine from it. Also, you should be able to put your hands on the lines to and from the pump and "feel" the fluid going through.
If you don't have cylinders hooked up to the remotes, the engine should pull down a bit when you cycle them...
Another idea if you don't have cylinders - take a hose and make a loop from one outlet to the other on a remote so the fluid can just make the loop through.
I have a feeling that fluid at the priming plug doesn't necessarily mean the pump is working... did you try a bit of pressure in the reservoir? Needs to be running when you pressurize so the pump sucks the oil.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
