Re: Easy steering wheel removal?
Posted by Janicholson on March 27, 2008 at 16:34:26 from (66.173.50.109):
In Reply to: Easy steering wheel removal? posted by M inMo on March 27, 2008 at 16:12:16:
If the solution below seems to be reluctant, Get the puller tight, and use a thin cold chisel to make 3 or 4 radial strike "dents" around the area the nut and washer were pressing on. This spreads the metal and shocks the sleeve without distorting it too much. Heat destroys the plastic in a big way. threading the shaft after beating it to death is also not the way. JimN
