There are some detent balls in there with springs that hold the gears in position. If one of the shifters is sliding without resistance, the detent ball on that side may be missing or the spring broken. Unfortunately to replace these, you have to split the tractor in front of the transmission. The shifter rods have to be pulled out the front of the transmission after you remove the pressed in plugs. The springs and balls will then pop out of their seats. If you have to do this, might as well replace the seal on the transmission input shaft and check the bearing for play as well. A loose front bearing and leaking tranny shaft seal are common. My Cub was missing the detent ball on one side and had a broken gear tooth. I suspect the gear tooth got broken when the gear slid into mesh while still in gear on the other side. Nothing to keep it from doing that if the detent ball is missing or the spring broken.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
