Re: 1942 M large oil filter
Posted by RustyFarmall on March 28, 2008 at 08:31:30 from (209.152.78.71):
In Reply to: 1942 M large oil filter posted by Dick fm Iowa on March 28, 2008 at 04:16:02:
There appears to be some confusion here. The early Ms used an oil filter that was much bigger, not to be confused with the later tall filter that was shared with the early H. The later Hs used the short filter, the later Ms still use the tall filter, but it is not as large in diameter as what was used on the early M.
Today's Featured Article - Talk of the Town: Repairin a Gas Tank - by Staff. This interesting discussion is from the Tool Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
