Re: Easy steering wheel removal?
Posted by rumplestiltskin on March 28, 2008 at 10:31:57 from (65.216.75.111):
In Reply to: Easy steering wheel removal? posted by M inMo on March 27, 2008 at 16:12:16:
The steering wheel on my 300 Utility was stuck tight (puller-proof) until I heated the hub just enough to let some candle wax seep into the hub/shaft junction. Then it came right off.
Mark W. in MI
