Re: SCORE!!
Posted by glennster on March 28, 2008 at 18:32:13 from (68.60.242.156):
In Reply to: Re: SCORE!! posted by JT on March 28, 2008 at 17:54:30:
it would help too if you shined up the inside of the terminal with some sandpaper, helps the solder stick better.
