Posted by JT on March 28, 2008 at 17:54:30 from (70.12.156.4):
In Reply to: SCORE!! posted by Mike CA on March 28, 2008 at 17:38:04:
Mike, the soldering is the easy part, get you some rosin core solder, put your terminal in a vise, take a propane torch heat the terminal fill 1/2 to 3/4 full of solder, have your cable stripped back before hand, after the solder is melted, stick the cable in the melted solder in the terminal heat for another 10-15 seconds after you put cable in terminal, to get a little heat in the cable and let it cool. Jim
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
