Re: Hand cranking
Posted by JT on March 29, 2008 at 07:02:08 from (70.226.209.165):
In Reply to: Hand cranking posted by BEL@IN on March 29, 2008 at 06:36:01:
Battery igntion systems need decent voltage to fire correctly, so if battery is a little low, you will get weak voltage to igntion system, could cause to fire out of time, and could kick you. I agree with Allan, cranks are hanging in shed, I have a heavy jump pack for the low battery situation.
Jim
