Re: Super-A pressure plate
Posted by Coax on March 30, 2008 at 11:55:29 from (68.26.127.34):
In Reply to: Super-A pressure plate posted by P and R Pete on March 30, 2008 at 10:44:01:
The Linkage is extended all the way out.as it should when your previous plate gave out.Clean off paint,Spin back your Linkage all the way back in.Replace your clutch,Reset linkage back out to spec.adjust to taste........
