Re: Super-A clutch alignment
Posted by gene bender on March 30, 2008 at 13:01:11 from (67.55.226.69):
In Reply to: Super-A clutch alignment posted by P and R Pete on March 30, 2008 at 11:51:45:
When you roll it together and it stops put the pto in gear and turn the belt pulley over and you can feel it inguage the splines. I like to have the plugs out so you can turn the engine over as they come together with the belt pulley or the pto shaft. The input shaft does have some movement up and down and sideways the end of the shaft will line up on the clutch plate and when you turn it over the splines will line up.
