Thanks for all the replies guys. I was thinking the same thing as most of you on it. The tractor would be bought and kept and more than likely restored. The steel that are on it are probably made up ones, as it is onwed by an amishman and around here they usually make up their own steel for their tractors. If we can strike a deal should be a good addition to the other M's and H's we have.
Again thanks for the replies and you comfirmed what I was allready thinking. Just wanted to see if my thinking was inline or not.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
