I'd for dang sure ensure it's a SMTA before giving that kinda money. I'd check the SN on the plate. If the plate is gone I'd be suspect. Check the casting codes on the belly of the machine. I'm not sure what the codes are off the top of my head but there are casting differences between the later 400's/450's and the SMTA's. Make sure you aren't buying a homemade SMTA. I've been hearing about some of them popping up out there. It might be exactly like you say but you better be sure it is before giving $2k for a machine that's only worth a couple hundred if it turns out to be a phony.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
