Re: wd9 value
Posted by mulcher on March 30, 2008 at 16:53:25 from (64.187.74.221):
In Reply to: wd9 value posted by dwsc on March 30, 2008 at 11:20:41:
We gave $400 for a WD9 with bad tires and the engine was stuck. We wanted the wheel weights, injector pump and the M&W hydraulic pump.
Brian
