field circuit resistance on Farall B
Posted by dads b on March 30, 2008 at 20:55:34 from (72.26.85.240):
Can any of you guys tell me where I could find a field circuit resistor for my 6 volt B? It goes in the switch box and causes a reduction of the generator output when the lights are off so the battery is not overcharged and damage is done to the generator. If I can't find one, besides always running the lights, what should I do? Also, What is the correct type and amperage of the glass fuse in the switch box? Mine is burnt out. I am just rebuilding this tractor and had the generator repaired and tested. The damage to the fuse and resistor was from before the restoration started.
Thanks!
