BIG BORE 20 said: (quoted from post at 20:51:04 03/30/08) VA Gasman,
I have had mice get inside the bellhousing through the timing hole in the front. They built a nest and wet in there and made a mess. You can pull the little plate off the bottom of the back cover, There are two bolts to remove it and check things out. Some guys over greased the throw out bearing this would be a good time to clean extra grease out of there. I would not put something to hold the clutch down it will compress the springs in the pressure plate that might weaken them in my opinion. The serial number is in three places, Tag on tool box, motor block, and frame rail all three #'s match on my tractors.
I have heard both sides of the weak spring argument. Mechanical Engineer friend said that good springs will not be weakened if stored compressed or with tension. To many "old boys" have been doing it for too many years for it not to work. I don't think they'd want to make more work for themselves long term if it weakened the springs to block a clutch.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
