VA Gasman, I have had mice get inside the bellhousing through the timing hole in the front. They built a nest and wet in there and made a mess. You can pull the little plate off the bottom of the back cover, There are two bolts to remove it and check things out. Some guys over greased the throw out bearing this would be a good time to clean extra grease out of there. I would not put something to hold the clutch down it will compress the springs in the pressure plate that might weaken them in my opinion. The serial number is in three places, Tag on tool box, motor block, and frame rail all three #'s match on my tractors.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
