Re: Cub Lo-Boy Fan Assembly Yoke
Posted by Haas on March 31, 2008 at 18:03:46 from (12.65.36.188):
In Reply to: Re: Cub Lo-Boy Fan Assembly Yoke posted by Haas on March 31, 2008 at 17:57:23:
Did not mention above, but you have to pull the crank pulley to replace the support for the fan pulley. The support is part of the front engine cover. That is why is was brazed instead of replaced. While you are into it, also get yourself a new front engine seal since the seal is mounted in the front engine cover. To do the job properly, you will also need a new front cover gasket.
