Re: Farmall ??
Posted by Keith-OR on April 02, 2008 at 12:06:41 from (207.200.116.7):
In Reply to: Farmall ?? posted by Keith-OR on April 02, 2008 at 09:16:57:
Well, I went and to a close look at this unit, definently mickey-moused the power-adjust wheels on. Welded up some sort of brackets (if you can call it a weld, looks more like grease gun welds)to hold the wheels to the original centers. If the hydraulics run from PTO pump,it is no longer on there. Also decals say Super A, but no factory hydraulics.
Keith & Shawn(Spec.Olympic Champion)
Here are some more pictures
third party image
third party image
third party image
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
