Re: International 484 clutch
Posted by karl f on April 02, 2008 at 15:33:36 from (64.83.221.111):
In Reply to: International 484 clutch posted by James westinghouse on April 02, 2008 at 13:59:36:
we have a bad ignition switch on the 685. when you push the clutch in sometimes it sounds like bad things are going on with the clutch.
(on ours) It's actually the starter trying to engage the flywheel that"s already turning. quick test: wiggle the key switch with the clutch pressed in and it goes away. hope this helps you before you tear open the tractor.
karl f
