Posted by JimB2 on April 02, 2008 at 18:59:01 from (99.241.179.24):
In Reply to: International 484 clutch posted by James westinghouse on April 02, 2008 at 13:59:36:
Hi James, have a 454 that has been doing the same thing for years. We replaced clutch, throwout and release bearing and still does it. If you lift the Hi/Lo/Rev shift lever slightly above the N position does the rattle stop? Also the rattle is more noticeable if the range transmission is in 3rd or 4th gear.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
