Re: It's ALIVE!!
Posted by Bob Kerr on April 02, 2008 at 21:52:33 from (205.188.116.73):
In Reply to: It's ALIVE!! posted by Mike CA on April 02, 2008 at 21:33:26:
Don"t you just love it when a plan comes together! Farmer may be right about the oil leak. not too bad of a fix, but can be a pain the first time. If it is the upper shaft it may be a bad bearing,(common problem) but should be able to get to that without pulling the top off the tranny. see what you can see through the inspection plates near the pump.
