Re: MD starts hard on gas
Posted by Bob M on April 03, 2008 at 07:11:22 from (151.190.254.108):
In Reply to: MD starts hard on gas posted by WadeMN on April 02, 2008 at 20:35:49:
Somehow your engine is running lean in the gasoline mode. Possible causes:
- Obstruction in the carb fuel circuit (sounds like you've already checked for this)
- Carb float level set too low. Or the float lockup linkage is not letting the float drop all the way when it's in gas mode.
- Carb air valve disc gap set too wide (the gap is adjustable on early carbs - not sure if it is on the later ones...)
- Manifold butterfly valves are not closing fully in gas mode (linkage adjustment or damaged butterfly plate(s)).
- Air leak at the carb or head manifold gasket.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
