Posted by Mich John on April 03, 2008 at 07:52:39 from (76.122.171.26):
In Reply to: International 484 clutch posted by James westinghouse on April 02, 2008 at 13:59:36:
Does the neutral rattle (with clutch out) occur more frequently (or with more intensity) when the tractor is warmed up? Does light foot pressure on the clutch pedal cause it to go away - if so, it just might be "gear rattle" which is not nice to have but it does NO harm o/wise. Many factors go into this issue but poor engine idle quality, worn clutch disc, low viscosity trans gear oil, etc can aggrivate it. If NOT described as above, look for other causal factors.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
