Mark Carey H ?
Posted by 55 50 Ron on April 03, 2008 at 07:58:03 from (216.114.212.31):
Mark, Did you get your "H" to charge? Does it have a magneto or distributor ignition? I would expect a magneto based on your other posts. If it has the magneto that would help explain why there is no small wire from the ammeter to battery. Someoone may have taken that wire loose and just plopped a 12 volt batttery in there for starting only, since as someone else posted, it will start many times on a 12 volt battery without need for re-charging.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
