Re: HELP ! Setting a ring and pinion in an H (Howls)
Posted by ihc49er#2 on April 03, 2008 at 19:57:01 from (216.123.197.189):
In Reply to: HELP ! Setting a ring and pinion in an H (Howls) posted by Wayne Rimathe on April 03, 2008 at 18:21:15:
once the howel is there you wont get rid of it with adjustments, because the pattern is already worn in.it has to be set properly new.you can adjust the backlash and move pinion where it looks halfass good on the crown, but you wont get a good pattern once its in that shape.the remedy is a new one but you dont want to go there so you will have to get used to a howel or whine.the used one you put in you needed the lash and should have checked the pattern before disassembly, it would have showed if it was worth attacking.
