Re: Farmall H hydraulics question
Posted by Janicholson on April 04, 2008 at 06:05:16 from (199.17.6.122):
In Reply to: Farmall H hydraulics question posted by Dean_Wheeler on April 04, 2008 at 04:36:30:
You have a two way valve hooked up on one way use. The B port must be hooked up to the return to the tank port, or a one way valve used to operate the system. It is trying to dump pressure into the remote hose, and is wrong. If you need only the loader, just hook it up to the front right, and front left Liftall elbows on the side of the trans, and use the rod to control the lifting. A simple pressure rated 1/4 turn valve in the line going to the valve you have, and additional 1/4turn valves in the loader hoses, would allow you to use the existing valve (connected to a two way cylinder on the remotes with a second hose running from the A port, to the rear) I hope this makes sense. JimN
