Re: Farmall H hydraulics question
Posted by Dean_Wheeler on April 04, 2008 at 06:31:27 from (136.181.195.28):
In Reply to: Re: Farmall H hydraulics question posted by Allan In NE on April 04, 2008 at 06:25:41:
Just so everyone is clear, I only have 1 valve (aftermarket), not tied to the lift-all (I think the lift-all resevoir is being used, but just as a tank, since that's where the lines run. However, I don't utilize the H's standard hydraulic lever for anything. I'm not even sure it has one.).
The tractor has live-hydraulics running off of a distributor mounted pump.
