Re: Farmall H hydraulics question
Posted by Allan In NE on April 04, 2008 at 06:25:41 from (148.78.243.24):
In Reply to: Farmall H hydraulics question posted by Dean_Wheeler on April 04, 2008 at 04:36:30:
It will work, but lowering the loader is a two-step process.
Move your tractors hydralic lever to the down position and then move that loader's valve again to "up" just as if you were trying to raise the loader.
Since the tractor's lever is in the "dump" position, the weight of the loader will force the oil to flow backwards and the loader will then lower.
Someone just plumbed that valve in there to "split" the use of the hydraulics. When you go to use the rear hydraulics on an implement, you'll have to use the same process to lower that implement as well.
Allan
