Re: Farmall H hydraulics question
Posted by Janicholson on April 04, 2008 at 08:17:32 from (199.17.6.122):
In Reply to: Re: Farmall H hydraulics question posted by Dean_Wheeler on April 04, 2008 at 06:26:12:
Starting with new info:
Ignore the 1/4turn valves, they assumed a Liftall.
All you need is a one way control valve for an open center system to control the loader.
Attach the valve so it is easy to use.
Connect the "return to tank" port of your existing valve to the input port of the new valve. connect its pressure port to a t that connects to the cylinders on the loader.
Connect its return to tank to the tank return.
To "fix" the existing valve, ujst put an additional hose and coupler on the B port and parallel the other remote hose to allow 2 way attachments. JimN
