I haven't done any additional testing, it just kind of dawned on me what might be going on and I wanted to verify.
Aside from being annoying, does it hurt anything plumbed this way? I know the fix is to plumb B back to the tank (and even understand why!). Didn't understand the two 1/4 valves that were mentioned earlier. Probably more than I need to get into, as right now I just need the FEL.
If/when I need the rear remotes hooked up, I'll revisit. Just thought life would be easier at that point if I understood how things were now.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
