Re: Battery Going Dead Multimeter Question?
Posted by HAS on April 05, 2008 at 06:47:47 from (68.12.173.235):
In Reply to: Battery Going Dead Multimeter Question? posted by Larry Ed on April 04, 2008 at 17:30:21:
What I do is charge the battery with the battery charger, then disconnect the charger and read battery voltage. It should be about 12.8 volts, just under 13. Keep the meter on the battery while you start the engine. During starting the battery reading should not drop below 10 volts - if it does you have a bad battery. After starting you should read at least 14 volts or the alternator is not charging.
