Re: Farmall 706 LP tractor
Posted by El Toro on April 05, 2008 at 08:10:15 from (64.12.116.73):
In Reply to: Farmall 706 LP tractor posted by martin simmons on April 05, 2008 at 07:56:51:
You need to make sure you're getting fire to the sparkplugs. Rub the points with some 320 wet or dry until shiny. You will need a fully charged battery too. Is there propane still in the tank?
It should have an ignition switch like a tractor that runs on gasoline. Hal
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
