I have a 706 almost identical. I started by putting a battery on it, turning the switch on and checking the distributor to make sure there is juice to it. I was lucky because there was still some gas in the tank. I turned the valve and made sure there were no big leaks. Then I had to short accross the starter to turn it over because the button had gone bad. I used a little ether to get it started. (It hadn't run in several years.) Then it took off and ran, have not had any trouble with it starting since. The hitch came up on mine when the engine cranked.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
