Re: Farmall 706 LP tractor
Posted by a_lead on April 05, 2008 at 14:30:42 from (69.137.41.169):
In Reply to: Farmall 706 LP tractor posted by martin simmons on April 05, 2008 at 07:56:51:
If you can get another tractor close, disconnect the hydraulic hoses on the lift cylinders from the 706, and connect them to the other tractor. Use a pair off extension hoses (male/female) to reach the 2nd tractor if needed.
Use the hydraulic on the other tractor to raise the loader up. Then using 2 pieces of angle iron the same length, put 1 on each cylinder on the piston shaft so you can safety prop up the loader and release the pressure on the donor lift tractor. Use several hose clamps around the angle iron & piston to keep in place.
Then you can pull the 706 back to the house/shop/garage so it will be more convenient to work on, and if you drop something small it won"t get lost in the grass (don"t ask me how I know that).
Good luck. Edward
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
