Re: 140 tractor
Posted by 1fortyfanatic on April 05, 2008 at 16:02:19 from (4.228.9.134):
In Reply to: 140 tractor posted by Hugh MacKay on April 05, 2008 at 02:10:12:
Tracy, if the piece is worth salvaging, then braze or weld all crack lines carefully inside and out, then use a small grinder then sander to take the weld hump down to level with the rest of the part. Then you can prime and paint and it should look better than open seems and lumpy welds. While you have that part off the tractor (four bolts, two on bottom underneath and the two on the side), you can pound out any dents or bends. Good Luck.
Dave
