Re: No spark from mag
Posted by gene bender on April 06, 2008 at 02:33:48 from (67.55.226.69):
In Reply to: No spark from mag posted by ScottyHOMEy on April 05, 2008 at 15:32:13:
You do have the rotor lined up with the cap when it fires dont ya. When ya put it bnack in ya did have it lined up to fire on TDC and not 180 deg off. When i get a mag serviced i fasten in a vice and with plug grounded turn it over with batt powered drill so i can check impulse and then at speed for fire before i install in engine.
