farmall 140 oil pressures
Posted by kmm on April 06, 2008 at 08:10:54 from (75.117.65.47):
When first started and engine cold oil pressure on gauge appears around 30-40, but after warm up it looks to drop to 7-10 perhaps lower becouse needle will bounce at idle. Doesn"t blow smoke or use oil that I"ve noticed but does have some leaks around bottom oil pan. Runs and starts really well. Looking for comments and ideas. Could the oil passages around valves be clogged somewhat not allowing oil back down to pan where the guage and filter is at? Re-build or new rings?
